Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Kenwood DRV-N520 Dashcam Speaker Replacement
Ce dont vous avez besoin
  1. Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: étape 1, image 1 de 3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: étape 1, image 2 de 3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws from the device backing.
    • Remove the backing.
  2. Kenwood DRV-N520 Dashcam Speaker Replacement: étape 2, image 1 de 3 Kenwood DRV-N520 Dashcam Speaker Replacement: étape 2, image 2 de 3 Kenwood DRV-N520 Dashcam Speaker Replacement: étape 2, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the copper plate.
    • Remove the copper plate from the housing. The motherboard and capacitors should now be visible.
  3. Kenwood DRV-N520 Dashcam Speaker Replacement: étape 3, image 1 de 2 Kenwood DRV-N520 Dashcam Speaker Replacement: étape 3, image 2 de 2
    • Use the screwdriver to remove the two screws holding the motherboard in place.
    • Before attempting to remove the board, disconnect the camera by removing the ribbon cable from its corresponding connection on the board.
    • To remove the ribbon cable, use a plastic spudger to gently apply pressure to the lever that secures the cable in place while simultaneously applying a light pulling pressure on the ribbon cable.
    • Disconnect the speaker connections (red and black wires) from the motherboard by applying pressure to the clip on its corresponding socket.
    • Once all connections have been severed, gently remove the motherboard from the device casing.
    • The speaker unit and corresponding mounting hardware should now be visible.
  4. Kenwood DRV-N520 Dashcam Speaker Replacement: étape 4, image 1 de 2 Kenwood DRV-N520 Dashcam Speaker Replacement: étape 4, image 2 de 2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws from the speaker's mounting bracket.
    • Remove the speaker from the device.
To re-assemble your device, follow these steps in reverse order.
NathanGoodwin
Membre depuis le 01/30/20
139 Réputation
1 tutoriel rédigé
Équipe
ERAU-LAMOTHE-S20S14G1 Membre de l'équipe ERAU-LAMOTHE-S20S14G1
Local Repair Groups
4 membres
3 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 40
Total : 419
