Aller au contenu principal
Kenwood KDC-BT362U Button Replacement
Ce dont vous avez besoin
  1. Kenwood KDC-BT362U Button  Replacement, Front Panel: étape 1, image 1 de 1
    • Locate the face-plate eject button.
  2. Kenwood KDC-BT362U Button  Replacement: étape 2, image 1 de 2 Kenwood KDC-BT362U Button  Replacement: étape 2, image 2 de 2
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Kenwood KDC-BT362U Button  Replacement: étape 3, image 1 de 2 Kenwood KDC-BT362U Button  Replacement: étape 3, image 2 de 2
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Kenwood KDC-BT362U Button  Replacement: étape 4, image 1 de 2 Kenwood KDC-BT362U Button  Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Kenwood KDC-BT362U Button  Replacement: étape 5, image 1 de 1
    • Remove the front panel.
  6. Kenwood KDC-BT362U Button  Replacement, Button: étape 6, image 1 de 1
    • Use the Phillips #0 Screwdriver to remove the four screws.
  7. Kenwood KDC-BT362U Button  Replacement: étape 7, image 1 de 2 Kenwood KDC-BT362U Button  Replacement: étape 7, image 2 de 2
    • Use the plastic opening tool to pry it open.
  8. Kenwood KDC-BT362U Button  Replacement: étape 8, image 1 de 2 Kenwood KDC-BT362U Button  Replacement: étape 8, image 2 de 2
    • Lift and remove the motherboard to reveal the inside of the front panel.
  9. Kenwood KDC-BT362U Button  Replacement: étape 9, image 1 de 2 Kenwood KDC-BT362U Button  Replacement: étape 9, image 2 de 2
    • Use the plastic opening tool to lift up and remove the cover.
  10. Kenwood KDC-BT362U Button  Replacement: étape 10, image 1 de 1
    • The buttons are now able to be removed and replaced if damaged or missing.
2 autres ont terminé cette réparation.
Steven Chov
Membre depuis le 10/04/16
349 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 2-5, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 2-5, Cagle Fall 2016
USFT-CAGLE-F16S2G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 762
