Introduction
A blown fuse can render the KDC-BT565U unusable. Replacing of a dead fuse with a proper 10 amp car fuse can restore the unit to working condition. This guide shows you how to replace this fuse.
NOTE: This requires the KDC-BT565U unit to be unmounted from the car. This may require specialist assistance.
Ce dont vous avez besoin
The fuse can be found on the back of your radio indicated by the red square in the photo.
To reassemble, follow these instructions in reverse order.
4 autres ont terminé cette réparation.
7 commentaires
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
same problem, how to remove the receiver
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
