Aller au contenu principal
Kenwood KDC-BT565U Fuse Replacement
Ce dont vous avez besoin
  1. Kenwood KDC-BT565U Fuse Replacement, Fuse: étape 1, image 1 de 1
    • The fuse can be found on the back of your radio indicated by the red square in the photo.
  2. Kenwood KDC-BT565U Fuse Replacement: étape 2, image 1 de 2 Kenwood KDC-BT565U Fuse Replacement: étape 2, image 2 de 2
    • Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
    • Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
To reassemble, follow these instructions in reverse order.
4 autres ont terminé cette réparation.
Darren Evans
Membre depuis le 02/15/17
273 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S2-G5, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S2-G5, Lacy Spring 2017
USFT-LACY-S17S2G5
4 membres
11 tutoriels rédigés
7 commentaires
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
jasonfisher036@gmail.com - Réponse
it does not explain how to pull the reciever out.
d_lalande - Réponse
same problem, how to remove the receiver
Jason Armondo - Réponse
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Javier Castellanos - Réponse
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Jannie watkins -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 40
30 derniers jours : 152
Total : 21,254
