Aller au contenu principal
Introduction
Broken handle? Lid not closing completely?
This guide will show you how to remove and replace the brewer handle for the Keurig B70 Platinum if you're experiencing any problems with the handle. Before continuing with the guide, you're going to need a Phillips #2 screwdriver and T15 Torx screwdriver.
Pièces
Aucune pièce spécifiée.
  1. Turn off and unplug the Keurig before starting. Lay the Keurig on its back and open the lid. Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
    • Turn off and unplug the Keurig before starting.
    • Lay the Keurig on its back and open the lid.
    • Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
    • Be careful when removing the screws. There is a sharp puncture needle!
    • You may need to use tweezers to get the screws out.
  2. Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle. Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle.
    • Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Lift and pull the black plastic cover away from the Keurig. Lift and pull the black plastic cover away from the Keurig.
    • Lift and pull the black plastic cover away from the Keurig.
  5. Push the handle back and upward to detach it from the Keurig.
    • Push the handle back and upward to detach it from the Keurig.
Thu Hoang
Membre depuis le 17/10/2018
217 Réputation
2 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G6, Rose Fall 2018 Membre de l'équipe UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 194
