Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Keurig K-Duo Motherboard Replacement
Ce dont vous avez besoin
    1. Keurig K-Duo Motherboard Replacement, Rear Plastic Panels: étape 1, image 1 de 1
      • Turn the Keurig K-Duo upside down so the power cord is visible and facing you.
      Demander à FixBot
      Ajouter un commentaire
    2. Keurig K-Duo Motherboard Replacement: étape 2, image 1 de 3 Keurig K-Duo Motherboard Replacement: étape 2, image 2 de 3 Keurig K-Duo Motherboard Replacement: étape 2, image 3 de 3
      • Use a Phillips screwdriver to remove all four screws that secure the plastic panel.
      Demander à FixBot
    3. Keurig K-Duo Motherboard Replacement: étape 3, image 1 de 3 Keurig K-Duo Motherboard Replacement: étape 3, image 2 de 3 Keurig K-Duo Motherboard Replacement: étape 3, image 3 de 3
      • To remove the back panels, grip each side firmly.
      • Gently pull the panel outward toward yourself to release and fully detach the plastic hooks.
      Demander à FixBot
    1. Keurig K-Duo Motherboard Replacement, Motherboard: étape 4, image 1 de 2 Keurig K-Duo Motherboard Replacement, Motherboard: étape 4, image 2 de 2
      • Gently disconnect all eleven connectors from the motherboard.
      • Gently pull off the four remaining wire terminals.
      • It may be helpful to label each terminal for its original corresponding connection.
      • Be careful not to damage green wire. It will have to be removed by soldering.
      Demander à FixBot
    2. Keurig K-Duo Motherboard Replacement: étape 5, image 1 de 2 Keurig K-Duo Motherboard Replacement: étape 5, image 2 de 2
      • Pull out and flip the motherboard so the back is now facing you.
      • Desolder the solder pad connected to the green wire.
      • Re-solder the existing green wire to the new motherboard.
      Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Adrian Guzman
Membre depuis le 10/28/24
610 Réputation
4 tutoriels rédigés
Équipe
Cuesta, Team 10-3, Krynen Fall 2024 Membre de l'équipe Cuesta, Team 10-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G3
4 membres
45 tutoriels rédigés
2 commentaires de tutoriel
What are the 4 leads that protrude from the motherboard to a recess(covered) on the bottom of the Kuerig? Are these test points for the motherboard? If so, how do I test the board and what values should I look for?
Rich - Réponse Partager
How about post detailed instruction how to remove this board from the K-Duo 5100 machine. Not worry about the wires, I just can't see how to pry this board loose. Thanks.
Bronek - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 20
30 derniers jours : 114
Total : 1,850
