Introduction
This guide will show an individual how to replace the water filter in the Keurig K40. This will require access to a screwdriver.
Ce dont vous avez besoin
Flip the device on its side so that the metal faces you.
Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
Grip where the filter and the flow line connect and pull apart until they are separated.
Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
There is no ffilter on K-40 keurig maker
11 autres ont terminé cette réparation.
12 commentaires
Where do you obtain a new filter?
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
I need the filter, where do I buy a new Filter?
I added 2 O rings, one at the bottom of the water reservoir other in between the ripped hose and housing. It’s been 24hrs since repair and no leak
First of all I think this is a bunch of bull on Keurigs part A customer has to get screwdrivers and $@$* and take the thing apart to get to the filter and then if you screw it up then what and now I see people are not even getting answers on how to get a new filter thanks Keurig I think you should freaking give everybody a new Keurig without charging them
Seriously? You think any company will add screwdrivers to the buy of coffee maker? And you want the company give everyone a new system? That’s called bankruptcy. ? smh
I have the same question as others. Where is they a filter for K-40 ?
Where can I buy the bottom water filter housing? My rubber seal tore
K40 is the best easiest Keurig system takes apart easily clean all part, containers, whatever you see collection of scale or coffee buildup. The filter /screen will never falter or break if you clean this machine once a year as above. The basics every three months or so is to fill the water housing with straight white vinegar and run continuously till empty. Keep filling with clean water to empty till the vinegar smell/ taste is gone. My machine has run perfectly 7 years I bought in 2013. Today is 11/5/2021. I forgot to mention , I haven’t seen my steel screen ripped or torn nor any other plastic /rubber broken so I am sure they have to have these parts somewhere as they would be very cheap to buy.
