Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Keurig K40 Open/Close Sensor Replacement
Ce dont vous avez besoin
    1. Keurig K40 Open/Close Sensor Replacement, Top Water Pump: étape 1, image 1 de 1
      • Begin by removing the top cover from the device.
      • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
      Demander à FixBot
      Ajouter un commentaire
    2. Keurig K40 Open/Close Sensor Replacement: étape 2, image 1 de 1
      • Unscrew both 1.5mm screws located on the water pump.
      Demander à FixBot
    3. Keurig K40 Open/Close Sensor Replacement: étape 3, image 1 de 2 Keurig K40 Open/Close Sensor Replacement: étape 3, image 2 de 2
      • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
      • The water pump and pipe should now be loose and easy to move as shown.
      Demander à FixBot
    4. Keurig K40 Open/Close Sensor Replacement: étape 4, image 1 de 2 Keurig K40 Open/Close Sensor Replacement: étape 4, image 2 de 2
      • Pull on the point where the pipe meets the water pump.
      • The pipe will come loose and the water filter will be free and ready to be replaced.
      Demander à FixBot
    1. Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: étape 5, image 1 de 2 Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: étape 5, image 2 de 2
      • Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
      • Locate where the connections are soldered to the sensor
      Demander à FixBot
    2. Keurig K40 Open/Close Sensor Replacement: étape 6, image 1 de 1
      • Melt the solder that is connected to the sensor.
      • Be careful to avoid any rubber and try to only contact the metal making the connection.
      Demander à FixBot
    3. Keurig K40 Open/Close Sensor Replacement: étape 7, image 1 de 1
      • Put the replacement sensor back on the post that holds it and begin to solder the two metal connections back to the sensor.
      • Be careful not to touch the end of the soldering iron.
      Demander à FixBot
jonathan
Membre depuis le 02/08/16
816 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 6-1, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 membres
29 tutoriels rédigés
1 commentaire de tutoriel
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
John Fictum - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 51
Total : 4,599
