Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Keurig K40 Top Water Pump Replacement
Ce dont vous avez besoin
    1. Keurig K40 Top Water Pump Replacement, Top Water Pump: étape 1, image 1 de 1
      • Begin by removing the top cover from the device.
      • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
      Demander à FixBot
      Ajouter un commentaire
    2. Keurig K40 Top Water Pump Replacement: étape 2, image 1 de 1
      • Unscrew both 1.5mm screws located on the water pump.
      Demander à FixBot
    3. Keurig K40 Top Water Pump Replacement: étape 3, image 1 de 2 Keurig K40 Top Water Pump Replacement: étape 3, image 2 de 2
      • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
      • The water pump and pipe should now be loose and easy to move as shown.
      Demander à FixBot
    4. Keurig K40 Top Water Pump Replacement: étape 4, image 1 de 2 Keurig K40 Top Water Pump Replacement: étape 4, image 2 de 2
      • Pull on the point where the pipe meets the water pump.
      • The pipe will come loose and the water filter will be free and ready to be replaced.
      Demander à FixBot
5 autres ont terminé cette réparation.
Andrew Bornemann
Membre depuis le 02/08/16
488 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 6-1, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 membres
15 tutoriels rédigés
5 commentaires de tutoriel
I NEED ONE OF THESE! Where can I find one????
G Steve - Réponse Partager
This is a check valve, not the water pump.
Rick Koen - Réponse Partager
Please rename this article. The item is not a water pump.
tvyse46 - Réponse Partager
I viewed this to replace the pump. But after the checkvalve was replaced through these instructions my K40 works like new. Thank you.
Glenn Stanley - Réponse Partager
After 4 months of storage, my Keurig didn't operate correctly when I tried using it again. The "add water" blue light, the "heat" red light and the middle "coffee cup" blue light, all x3 lights, blinked together... and the unit was seized up it seamed when I would try using it. After pulling the bottom apart and checking all those tubes, I found this web page, and then put the bottom back together again, and removed the top part to get to the "water pump" [check valve actually], and blew into it; it was completely seized. I blew a short spurt really hard un-siezing it. That's all it took. It was stuck from being in storage, dried out and sealed as it dried out. I put everything back together and I had to run the unit a few times until everything worked as it should. I really enjoyed this thread and everyone's collaboration, as it solved the root of my problem, which I couldn't find resolution anywhere else. Thanks a bunch! Don't forget to click on and read the detailed comments people wrote for each step...
John Smith - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 54
Total : 11,011
