Introduction
I found a way to get access the USB port. But the really ugly place of the screws means that the back cover remains a bit loose or needs to be glued in place.
Ce dont vous avez besoin
A small cutting board and a slight hit with a hammer on it allows to break off the bottom side case. Inside resides the circuit board and the recharcheable battery - so be careful with the amount of force.
The bottom cover is held by screws that cannot be accessed/loosened without destroying the glued parts of the device.
With the hammering we break the plastic parts where the crews hold the cover. It worked better than I expected.
The cover is still connected to the main larger part of the keyboard with two flat cable. So be careful to keep these intact.
Now the PCB with the broken off USB jack is accessible. The soldering on the shield was really not so good. No wonder that it broke off so easily!
There is a brownish flat cable to the left in the picture. Another green flat cable goes to the back as seen in the picture. I took the second one out with a tweezer, which helped me to get good access for soldering back the USB jack.
But putting back the flat cable was a bit fiddly. So mybe others might find it better to try soldering with both flat cables still in place.
The cover can be snapped back on but will not hold very tight as the screw holders are broken now.
Some glue would hold it in place. Bets put some glue on the locations where the screw-points are.
2 autres ont terminé cette réparation.
Un commentaire
Nice! Youre the only one who succeeded. Gonna try this thanks!
