Aller au contenu principal
KidzLane Walkie-Talkie Press-to-speak button Replacement
Ce dont vous avez besoin
  1. KidzLane Walkie-Talkie Press-to-speak button Replacement, Press-to-speak button: étape 1, image 1 de 1
    • Place the Walkie-Talkie on a flat surface-preferably a table or a desk.
    • Flip the device over to where you see four screws in each corner.
    • Make sure you take out the batteries before proceeding.
  2. KidzLane Walkie-Talkie Press-to-speak button Replacement: étape 2, image 1 de 2 KidzLane Walkie-Talkie Press-to-speak button Replacement: étape 2, image 2 de 2
    • Using your Phillips head screwdriver, unscrew all four 4mm screws from each corner.
  3. KidzLane Walkie-Talkie Press-to-speak button Replacement: étape 3, image 1 de 1
    • Once you have unscrewed all four corners, open the device so it will be in two parts.
    • As you're opening the inside of the Walkie-Talkie, don't break off any wires within the device.
    • Taking the Phillips head screwdriver again, unscrew the three screws on the circuit board (green plate).
    • Separate these screws from the other four since they are different sizes.
  4. KidzLane Walkie-Talkie Press-to-speak button Replacement: étape 4, image 1 de 2 KidzLane Walkie-Talkie Press-to-speak button Replacement: étape 4, image 2 de 2
    • Take the circuit board out of the plastic casing.
    • Use the soldering device to iron the silver box (press-to-speak button), and then remove it from the circuit board.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Amin
Membre depuis le 02/13/16
642 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Wilson Spring 2016 Membre de l'équipe IUPUI, Team 1-1, Wilson Spring 2016
IUPUI-WILSON-S16S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 13
Total : 911
