Aller au contenu principal
Kindle 2 Screen Replacement
Ce dont vous avez besoin
  1. Kindle 2 Screen Replacement, Battery: étape 1, image 1 de 3 Kindle 2 Screen Replacement, Battery: étape 1, image 2 de 3 Kindle 2 Screen Replacement, Battery: étape 1, image 3 de 3
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
    I had a heck of time using the spudger. I have found that grabbing the corners and using my thumbs to push the plastic away worked like a champ.
    teamhudson - Réponse
    Thanks for this tip, was successful using the thumb method :)
    Rosie A. -
    to help get enough grip with my thumbs, I used a piece of old yoga mat to increase friction between thumbs and the top plastic piece
    Rosie A. -
    For anyone still looking for this in 2020, see my comment here for how to properly remove the back.
    Kindle 2 Teardown
    Dave76 - Réponse
  2. Kindle 2 Screen Replacement: étape 2, image 1 de 2 Kindle 2 Screen Replacement: étape 2, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
  3. Kindle 2 Screen Replacement: étape 3, image 1 de 2 Kindle 2 Screen Replacement: étape 3, image 2 de 2
    • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
  4. Kindle 2 Screen Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
  5. Kindle 2 Screen Replacement: étape 5, image 1 de 2 Kindle 2 Screen Replacement: étape 5, image 2 de 2
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
  6. Kindle 2 Screen Replacement, Wireless Card: étape 6, image 1 de 1
    • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
    • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
  7. Kindle 2 Screen Replacement: étape 7, image 1 de 1
    • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
    STEP 7.5 Remove Plastic Protector. There are 16 2.5mm screws keeping it in place. Remove them and the protector will come off easily. I used this guide a few months ago and it had a step here explaining this that now seems to be missing.
  8. Kindle 2 Screen Replacement: étape 8, image 1 de 2 Kindle 2 Screen Replacement: étape 8, image 2 de 2
    • Use your fingers to lift the left end of the wireless card.
    • Pull the card out of the slot.
  9. Kindle 2 Screen Replacement, Motherboard: étape 9, image 1 de 2 Kindle 2 Screen Replacement, Motherboard: étape 9, image 2 de 2
    • Remove 16 screws from the midframe.
  10. Kindle 2 Screen Replacement: étape 10, image 1 de 3 Kindle 2 Screen Replacement: étape 10, image 2 de 3 Kindle 2 Screen Replacement: étape 10, image 3 de 3
    • Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire.
    • Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
  11. Kindle 2 Screen Replacement: étape 11, image 1 de 3 Kindle 2 Screen Replacement: étape 11, image 2 de 3 Kindle 2 Screen Replacement: étape 11, image 3 de 3
    • Wedge the opening tool underneath the plastic ribbon and gently pull up to lift the brown connector flap.
    • Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it.
  12. Kindle 2 Screen Replacement: étape 12, image 1 de 1
    • Locate the next brown connector three inches to the right of the previous connector and repeat Step 10 to remove the plastic ribbon.
  13. Kindle 2 Screen Replacement: étape 13, image 1 de 2 Kindle 2 Screen Replacement: étape 13, image 2 de 2
    • Rotate the device 180 degrees and locate a smaller brown connector on the left side of the device.
    • Repeat Step 10.
  14. Kindle 2 Screen Replacement: étape 14, image 1 de 1
    • Push your finger down on the last plastic ribbon.
    • Slide your finger away from the connector to remove the last ribbon.
    This cable's connector also has a hinge that must be opened to put the cable back in properly.
    You don't have to remove this connector to look at the keyboard. Remove it only if you are looking to replace screen.
    Also the black connector can be popped open like the other brown ones, before you pull out the connector cable.
    Amit Saxena - Réponse
    This particular connector must be seated all the way, for the screen to work and it's not easy to get it back in all the way. Be sure to note how far in it is, before removing it.
    gruntso - Réponse
  15. Kindle 2 Screen Replacement: étape 15, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the motherboard located around the LAB126 logo.
  16. Kindle 2 Screen Replacement: étape 16, image 1 de 1
    • Grab the bottom corner of the motherboard and safely remove it from the Kindle.
    Does anyone know what the "-1.29" number means?
    Jan Andreas Knudsen - Réponse
  17. Kindle 2 Screen Replacement, Screen: étape 17, image 1 de 1
    • Flip the motherboard over so the screen is facing up.
    • Using your fingers, gently pull off the plastic header bar located at the top of the screen attached to the motherboard.
  18. Kindle 2 Screen Replacement: étape 18, image 1 de 3 Kindle 2 Screen Replacement: étape 18, image 2 de 3 Kindle 2 Screen Replacement: étape 18, image 3 de 3
    • The screen is attached to the motherboard with double sided tape.
    • Pry underneath all four sides of the device with the plastic opening tool to remove the screen from the motherboard.
25 autres ont terminé cette réparation.
Dayna Scott
Membre depuis le 04/16/13
955 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 12-32, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 membres
14 tutoriels rédigés
7 commentaires
Great guide!
My replacement screen came with a spudger like the one shown, but it was pretty mangled by the time I got the back off. I had much better luck with another spudger shaped like a guitar pick.
Yeah, the step to remove the inner plastic protector is missing. It is pretty obvious that it needs to happen, but it would be good to include in the guide.
The ribbon for the screen needs to be pushed in further than the other ribbons, and took a bit of wiggling. FYI for others attempting this!
Hannah - Réponse
I followed this guide, but the screen is still on the "Amazon Kindle" screen that was on the replacement when it came in the mail. I opened it to ensure the ribbons are all in place. It's fully charged (green light) and the computer can see it as a hard drive. Calibre can also see all the books are still in place. Any ideas what connection I need to recheck to get the replacement screen working? I'd love to get my old Kindle 2 back in business!
tanderson92 - Réponse
Answering my own question in case it helps anyone. It turns out the ribbon for the screen (the last one removed in Step 14) wasn't far enough in the connector. I was trying it with the line about even with the "39" on the board, which wasn't far enough. After the eBay seller kindly gave me some tips, I was able to manhandle the ribbon closer to the connector, and now the screen works great!
tanderson92 -
Where can I get one of those replacement screens?
Andie - Réponse
In order to be pre-prepared, (I'm pretty sure the double-sided tape holding the screen to the motherboard will need replacement after years of service) is the tape of the fairly thick foam variety or the much thinner plastic ribbon style?
Richard Herndon - Réponse
Are replacement screens still available for purchase?
Paul Roczniak - Réponse
Great guide. Look at the comments at step 14. If anyone is interested, If anyione is still interesed, in March 2017 I bought a replacement screen for US$15 here: https://www.aliexpress.com/item/Free-too...
A Finderle - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 37
Total : 22,223
