Aller au contenu principal
  1. Kindle Fire HD 2013 Speakers Replacement, Speakers: étape 1, image 1 de 3 Kindle Fire HD 2013 Speakers Replacement, Speakers: étape 1, image 2 de 3 Kindle Fire HD 2013 Speakers Replacement, Speakers: étape 1, image 3 de 3
    • Open up the device by using a plastic opening tool in order to avoid damaging the device.
    • To do so, find the seam along the outer edge of the device and use the plastic tool to pry the back panel up. Doing so may take some force and patience.
  2. Kindle Fire HD 2013 Speakers Replacement: étape 2, image 1 de 3 Kindle Fire HD 2013 Speakers Replacement: étape 2, image 2 de 3 Kindle Fire HD 2013 Speakers Replacement: étape 2, image 3 de 3
    • There are (4) 3mm T4 Torx screws between both speakers (two each). Remove the ones necessary for whichever speaker needs to be replaced.
  3. Kindle Fire HD 2013 Speakers Replacement: étape 3, image 1 de 3 Kindle Fire HD 2013 Speakers Replacement: étape 3, image 2 de 3 Kindle Fire HD 2013 Speakers Replacement: étape 3, image 3 de 3
    • After the screws are removed, locate the wire, follow it to where it connects to the main device, and pull up gently until it disconnects.
  4. Kindle Fire HD 2013 Speakers Replacement: étape 4, image 1 de 2 Kindle Fire HD 2013 Speakers Replacement: étape 4, image 2 de 2
    • Remove (2) 3mm T4 Torx screws from the bottom speaker.
  5. Kindle Fire HD 2013 Speakers Replacement: étape 5, image 1 de 2 Kindle Fire HD 2013 Speakers Replacement: étape 5, image 2 de 2
    • Same as Step 3, after the screws are removed, follow the wire to where it connects and pull up gently until it disconnects.
aaa
Membre depuis le 06/10/2016
721 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 2-3, Sullivan Fall 2016 Membre de l'équipe USF Tampa, Team 2-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 303
