Aller au contenu principal
Kindle Fire HD 6 Battery Replacement
Ce dont vous avez besoin
  1. Kindle Fire HD 6 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
    I wasn't sure that I would be able to fix my kindle. I did purchase another kindle, which was alright. I wanted a second kindle so with the purchase and my old one know fixed I am really glad. I feel if I have any future problems I will be able to fix it myself.
    RUBY PEOPLES - Réponse
    i had a battery that wouldn't even last a full day in the end. by accident i let the battery fall below 10% charge and when turned on it only showed the battery icon. I fully charged it and now i am having no problems with it. what i think happened is it reset the batteries memory and that was the problem. worth trying anyway before buying a new battery.
    soupamanx - Réponse
  2. Kindle Fire HD 6 Battery Replacement: étape 2, image 1 de 2 Kindle Fire HD 6 Battery Replacement: étape 2, image 2 de 2
    • Carefully separate the back panel from the rest of the device internals.
  3. Kindle Fire HD 6 Battery Replacement, Battery: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    iOpener
    $12.99
    J'achète
    • Gently pry the battery free from the adhesive holding it in place.
    • Take care not to pierce or rupture the battery, which can release dangerous chemicals.
    • If you're having trouble working the battery free, warm it up with an iOpener or hair dryer to soften the adhesive, and then slide a credit card behind the battery to break up the adhesive.
    • Be careful not to yank the battery out—you'll need to disconnect a connector before removing the battery completely.
  4. Kindle Fire HD 6 Battery Replacement: étape 4, image 1 de 2 Kindle Fire HD 6 Battery Replacement: étape 4, image 2 de 2
    • Remove the multi-colored connector that joins the battery and the motherboard by pulling it straight up.
    • Remove the battery.
    What if the connector on the motherboard to the battery got damaged in the process of removing the battery?
    minecraftmargaret - Réponse
18 autres ont terminé cette réparation.
Cassandra Beck
Membre depuis le 01/13/15
885 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 70-4, Forte Winter 2015 Membre de l'équipe Cal Poly, Team 70-4, Forte Winter 2015
CPSU-FORTE-W15S70G4
4 membres
12 tutoriels rédigés
2 commentaires
Thank you it worked for me.
A bit nervous breaking it down, once I got the back plate off it was very simple, unplugged the battery, reconnected put it back together fired it up , great advice.
Thanks again
Regards
Terry
terry pils - Réponse
The battery removal step did not sufficiently warn about how hard the adhesive used for the battery was, and using the spudger ended up piercing the battery when I tried to pry the battery off.
Sean Collins - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 23
Total : 8,221
