Introduction
The case of your Kindle Paperwhite gets a lot of abuse from everyday life. Replace a cracked or a scratched case to restore that fresh out-of-the-box feeling.
Ce dont vous avez besoin
Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
Hello, the original battery is 1420m Ah and 3.7VDC, but the buttery you offer to sell is 1600mAh, is it right? there is no problem with different mAh? mi kindle is the amazon kindle 1est generation
2 autres ont terminé cette réparation.
I found it easier to start this step off with one of the Opening Picks found in the iOpener pack.
NathanF - Réponse
The glue on bezel started to peel the sticky back protective layer off the screen for me - managed to smooth it back down, although now have an unsightly crease. I would try to hold the screen down when you pull the bezel off to stop damaging the screen.
Callum Rogers - Réponse
This step is most time consuming. Take you time and try not to scratch the bezel :)
Oleksii - Réponse
Couldn't get the plastic spudger under the edge of the bezel. A right-angle X-Acto blade was a satisfactory tool here.
dbrick - Réponse
The glue was VERY difficult...I used a trick, from taking apart phones, and used a hair drier to loosen up the glue...worked like a charm.
billkaris - Réponse
