Introduction
Amazon’s Kindle Paperwhite 3rd Generation possesses a GS957661, 3G motherboard. This guide requires that the Kindle is turned off, and that a plastic opening tool, angled precision tweezers, and a PH000 screwdriver are used.
Outils
Pièces
Aucune pièce spécifiée.
Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
Gently lift the battery from the frame.
We had a Kindle that unfortunately took a dunk in (clean) water. It was then inoperative. I followed this guide, and took the battery out, let everything dry for a few days, then replaced the battery. Now it works fine! Thanks!
Flip the black latch with a plastic opening tool, and then gently pull back the orange ribbon cable.
10 autres ont terminé cette réparation.
5 commentaires
Tip, heat the front bezel to soften the glue.
I totally know how to fix my kindle but I don’t know where to get the part. I broke the tip to the ribbon cable for the only %#*@ button on the device. do they sell those here?
Be very careful along the lower left side, where the cable to the touchscreen can be easily cut with a plastic spudger.
John Kenny - Réponse
Be careful at the top of the 3G version. The wifi and cell antennas are located along here.
James Sullivan - Réponse
I can’t get my spudger in to start lifting. Any advice?
Davey - Réponse
it takes a bit of force to first insert the spudger into the crack
bonjoukhadar -
