Aller au contenu principal
Kindle Touch 3G Card Housing Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Kindle Touch 3G Card Housing Replacement, Back Cover: étape 1, image 1 de 3 Kindle Touch 3G Card Housing Replacement, Back Cover: étape 1, image 2 de 3 Kindle Touch 3G Card Housing Replacement, Back Cover: étape 1, image 3 de 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
  2. Kindle Touch 3G Card Housing Replacement: étape 2, image 1 de 2 Kindle Touch 3G Card Housing Replacement: étape 2, image 2 de 2
    • Gently lift the bottom and slide the panel off.
  3. Kindle Touch 3G Card Housing Replacement, Battery: étape 3, image 1 de 3 Kindle Touch 3G Card Housing Replacement, Battery: étape 3, image 2 de 3 Kindle Touch 3G Card Housing Replacement, Battery: étape 3, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch 3G Card Housing Replacement: étape 4, image 1 de 3 Kindle Touch 3G Card Housing Replacement: étape 4, image 2 de 3 Kindle Touch 3G Card Housing Replacement: étape 4, image 3 de 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: étape 5, image 1 de 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: étape 5, image 2 de 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: étape 5, image 3 de 3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
3 autres ont terminé cette réparation.
Adam Yerly
Membre depuis le 01/20/15
1 933 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 19-5, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 membres
8 tutoriels rédigés
2 commentaires
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
Curious_Guy_Threepwood - Réponse
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
Darren John de Lima -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 14
Total : 1,948
