Aller au contenu principal
Kindle Touch Rear Casing Replacement
Ce dont vous avez besoin
  1. Kindle Touch Rear Casing Replacement, Back Cover: étape 1, image 1 de 3 Kindle Touch Rear Casing Replacement, Back Cover: étape 1, image 2 de 3 Kindle Touch Rear Casing Replacement, Back Cover: étape 1, image 3 de 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
  2. Kindle Touch Rear Casing Replacement: étape 2, image 1 de 2 Kindle Touch Rear Casing Replacement: étape 2, image 2 de 2
    • Gently lift the bottom and slide the panel off.
  3. Kindle Touch Rear Casing Replacement, Battery: étape 3, image 1 de 3 Kindle Touch Rear Casing Replacement, Battery: étape 3, image 2 de 3 Kindle Touch Rear Casing Replacement, Battery: étape 3, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Rear Casing Replacement: étape 4, image 1 de 3 Kindle Touch Rear Casing Replacement: étape 4, image 2 de 3 Kindle Touch Rear Casing Replacement: étape 4, image 3 de 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch Rear Casing Replacement, Bezel: étape 5, image 1 de 2 Kindle Touch Rear Casing Replacement, Bezel: étape 5, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  6. Kindle Touch Rear Casing Replacement: étape 6, image 1 de 3 Kindle Touch Rear Casing Replacement: étape 6, image 2 de 3 Kindle Touch Rear Casing Replacement: étape 6, image 3 de 3
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
  7. Kindle Touch Rear Casing Replacement, Rear Casing: étape 7, image 1 de 1
    • Use your Phillips #00 srewdriver to remove the indicated screws.
    • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
  8. Kindle Touch Rear Casing Replacement: étape 8, image 1 de 2 Kindle Touch Rear Casing Replacement: étape 8, image 2 de 2
    • With the screws removed, gently remove the case from the internals.
Adam Yerly
Membre depuis le 01/20/15
1 933 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 19-5, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 1,153
