Aller au contenu principal
Kindle Voyage Wifi Antenna Replacement
Ce dont vous avez besoin
  1. Kindle Voyage Wifi Antenna Replacement, Back Panel: étape 1, image 1 de 2 Kindle Voyage Wifi Antenna Replacement, Back Panel: étape 1, image 2 de 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Wifi Antenna Replacement: étape 2, image 1 de 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Wifi Antenna Replacement: étape 3, image 1 de 3 Kindle Voyage Wifi Antenna Replacement: étape 3, image 2 de 3 Kindle Voyage Wifi Antenna Replacement: étape 3, image 3 de 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Wifi Antenna Replacement: étape 4, image 1 de 2 Kindle Voyage Wifi Antenna Replacement: étape 4, image 2 de 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: étape 5, image 1 de 2 Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: étape 5, image 2 de 2
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
  6. Kindle Voyage Wifi Antenna Replacement: étape 6, image 1 de 3 Kindle Voyage Wifi Antenna Replacement: étape 6, image 2 de 3 Kindle Voyage Wifi Antenna Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
Sean Yap
Membre depuis le 01/22/15
1 351 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 19-12, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 membres
10 tutoriels rédigés
Un commentaire
Re Kindle Voyage Wifi Antenna Replacement guide: I cannot find the WiFi antenna bar on your website to purchase a replacement. Do you sell it?
carol cooper - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 1,985
