Aller au contenu principal
Kingston HyperX Cloud II Microphone Wire Repair
Ce dont vous avez besoin
  1. Kingston HyperX Cloud II Microphone Wire Repair, Kingston HyperX Cloud II Microphone Wire Repair: étape 1, image 1 de 1
    • Pulling along the edges, take off the padding.
  2. Kingston HyperX Cloud II Microphone Wire Repair: étape 2, image 1 de 2 Kingston HyperX Cloud II Microphone Wire Repair: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
  3. Kingston HyperX Cloud II Microphone Wire Repair: étape 3, image 1 de 3 Kingston HyperX Cloud II Microphone Wire Repair: étape 3, image 2 de 3 Kingston HyperX Cloud II Microphone Wire Repair: étape 3, image 3 de 3
    • Remove the inside bracket support and then remove the outside bracket support. Then set it to the side.
    • After removing the bracket support. Expand and remove the microphone speaker from the frame.
  4. Kingston HyperX Cloud II Microphone Wire Repair: étape 4, image 1 de 3 Kingston HyperX Cloud II Microphone Wire Repair: étape 4, image 2 de 3 Kingston HyperX Cloud II Microphone Wire Repair: étape 4, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 7.9 mm screws from the red support attached to the microphone speaker.
  5. Kingston HyperX Cloud II Microphone Wire Repair: étape 5, image 1 de 3 Kingston HyperX Cloud II Microphone Wire Repair: étape 5, image 2 de 3 Kingston HyperX Cloud II Microphone Wire Repair: étape 5, image 3 de 3
    • Separate the red frame support from the microphone speaker by putting it to the side.
  6. Kingston HyperX Cloud II Microphone Wire Repair: étape 6, image 1 de 2 Kingston HyperX Cloud II Microphone Wire Repair: étape 6, image 2 de 2
    • Remove the four 11 mm screws on the speaker frame with a Phillips #2 screwdriver.
  7. Kingston HyperX Cloud II Microphone Wire Repair: étape 7, image 1 de 3 Kingston HyperX Cloud II Microphone Wire Repair: étape 7, image 2 de 3 Kingston HyperX Cloud II Microphone Wire Repair: étape 7, image 3 de 3
    • Remove the microphone speaker frame.
    • Open the microphone speaker to reveal circuitry.
    • Solder the detached red wire onto the driver.
    • Be cautious not to solder the wrong wire.
Équipe
IUPUI, Team 1-4, Harley Spring 2023 Membre de l'équipe IUPUI, Team 1-4, Harley Spring 2023
IUPUI-HARLEY-S23S1G4
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 57
Total : 933
