Aller au contenu principal
Kingston HyperX CloudX Ear Pads Replacement
Ce dont vous avez besoin
  1. Kingston HyperX CloudX Ear Pads Replacement, Ear Pads: étape 1, image 1 de 1
    • Place one finger on the inside of the cushion and place the other finger on the outer rim of the ear pad cushion.
    • Gently pull the ear pad away from the headset, removing the flap from the groove until the old ear pads are fully detached.
  2. Kingston HyperX CloudX Ear Pads Replacement: étape 2, image 1 de 1
    • Take the new ear pad and slide the top side of the flap into the groove of the ear cup.
    • Once the flap is inside the groove, slide it all the way in to make sure the flap is secured inside the groove.
  3. Kingston HyperX CloudX Ear Pads Replacement: étape 3, image 1 de 1
    • Squeeze the top part of the cushion into the earcup to keep it secure and prevent the flap from sliding out of the groove.
    • Make sure to keep a tight squeeze onto the cushion until it is fully secured onto the earcup to prevent the flap from slipping out.
  4. Kingston HyperX CloudX Ear Pads Replacement: étape 4, image 1 de 1
    • Slowly start going around the outside of the earcup and stretching the cushion so that the flap is secured into the groove.
  5. Kingston HyperX CloudX Ear Pads Replacement: étape 5, image 1 de 2 Kingston HyperX CloudX Ear Pads Replacement: étape 5, image 2 de 2
    • Push the flap further into the groove by taking a spudger and going around the outside of the headset slowly pushing the spudger into the groove to make sure the flap is fully secured into the groove.
    • If you do not have a spudger, you can also use a credit card instead.
  6. Kingston HyperX CloudX Ear Pads Replacement: étape 6, image 1 de 1
    • Squeeze the ear cushion and move it slightly back and forth to ensure the flap is secured.
    • Repeat on the other side.
Ligne d'arrivée
Sam Bloch
Membre depuis le 03/01/23
133 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 35
Total : 459
