Aller au contenu principal
Kirby G5 Vacuum Belt Replacement
Ce dont vous avez besoin
  1. Kirby G5 Vacuum Belt Replacement, Vacuum Belt: étape 1, image 1 de 1
    • Place the vacuum at an angle most comfortable and easy to access with the bottom facing upwards.
  2. Kirby G5 Vacuum Belt Replacement: étape 2, image 1 de 2 Kirby G5 Vacuum Belt Replacement: étape 2, image 2 de 2
    • Remove the three screws holding the base plate to the body of the vacuum using a flat head screwdriver.
    • Place the plate to the side.
  3. Kirby G5 Vacuum Belt Replacement: étape 3, image 1 de 1
    • Simply slide the roller out of the vacuum.
    • The belt is attached to the roller on either side.
  4. Kirby G5 Vacuum Belt Replacement: étape 4, image 1 de 2 Kirby G5 Vacuum Belt Replacement: étape 4, image 2 de 2
    • Slide the vacuum belt out from beneath the wheel holding it in place.
  5. Kirby G5 Vacuum Belt Replacement: étape 5, image 1 de 1
    • Insert your new belt and pop the roller back into place.
  6. Kirby G5 Vacuum Belt Replacement: étape 6, image 1 de 2 Kirby G5 Vacuum Belt Replacement: étape 6, image 2 de 2
    • Secure the plate once again until it clicks into the made grooves.
    • Secure the three screws until tightened.
Make sure to test the vacuum and securely tighten all screws. With that, you’re good to go!
Gina Trojano
Membre depuis le 04/22/21
157 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S2-G23, Sinclaire Spring 2021 Membre de l'équipe UMass Dartmouth, Team S2-G23, Sinclaire Spring 2021
UMASSD-SINCLAIRE-S21S2G23
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 58
Total : 1,118
