Introduction
Use this guide to replace a kitchen faucet (single-hole faucet and pull-down spray).
A simple problem of a kitchen faucet can be fixed by replacing a part or a couple of parts.
- A faucet that leaks from its neck.
- A broken kitchen faucet pull-out spray head.
- How to fix a leaky faucet.
- How to clean a Kitchen Aerator.
However, if the faucet has multiple problems, such as leakage, a squeaky handle, rust, or low water pressure, it might need to be replaced. If the replacement is done by a plumber, including removing an old faucet and installing a new one, it could cost at least $150, but the labor fee can be saved by replacing the faucet yourself.
Ce dont vous avez besoin
Rotate the hot and cold water valve knobs under the sink clockwise to turn off the water.
Turn on the faucet to relieve the pressure and any remaining water for about one minute.
2 autres ont terminé cette réparation.
Un commentaire
Great guide on kitchen faucet replacement! I was able to follow the steps and successfully replace my old faucet with a new one. The pictures and detailed instructions made the process much easier. Thank you for sharing this useful information!
