Aller au contenu principal
Kitchen Gourmet WM-6105 Disassembly
Ce dont vous avez besoin
  1. Kitchen Gourmet WM-6105 Disassembly, Water Heater: étape 1, image 1 de 3 Kitchen Gourmet WM-6105 Disassembly, Water Heater: étape 1, image 2 de 3 Kitchen Gourmet WM-6105 Disassembly, Water Heater: étape 1, image 3 de 3
    • Remove the three rubber feet.
    • You can pinch them quite hard to pull them out as they are not held in by adhesive.
  2. Kitchen Gourmet WM-6105 Disassembly: étape 2, image 1 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 2, image 2 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 2, image 3 de 3
    • Remove the 7 12 mm Phillips #1 screws.
    • The white plastic bar holding two of the screws comes loose once they are unscrewed.
  3. Kitchen Gourmet WM-6105 Disassembly: étape 3, image 1 de 1
    • Remove the white plastic bar holding the cord.
  4. Kitchen Gourmet WM-6105 Disassembly: étape 4, image 1 de 2 Kitchen Gourmet WM-6105 Disassembly: étape 4, image 2 de 2
    • Push the cord through the opening while pulling the base away from the body.
  5. Kitchen Gourmet WM-6105 Disassembly: étape 5, image 1 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 5, image 2 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 5, image 3 de 3
    • Flip the hot pot so it it right-side-up.
  6. Kitchen Gourmet WM-6105 Disassembly: étape 6, image 1 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 6, image 2 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 6, image 3 de 3
    • Unscrew the single 8 mm Phillips screw holding the temperature dial in place.
  7. Kitchen Gourmet WM-6105 Disassembly: étape 7, image 1 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 7, image 2 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 7, image 3 de 3
    • Remove the dial from plastic housing knob.
  8. Kitchen Gourmet WM-6105 Disassembly: étape 8, image 1 de 2 Kitchen Gourmet WM-6105 Disassembly: étape 8, image 2 de 2
    • Unscrew the eight 6 mm screws holding in the metal brackets.
  9. Kitchen Gourmet WM-6105 Disassembly: étape 9, image 1 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 9, image 2 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 9, image 3 de 3
    • Remove the metal brackets.
  10. Kitchen Gourmet WM-6105 Disassembly: étape 10, image 1 de 2 Kitchen Gourmet WM-6105 Disassembly: étape 10, image 2 de 2
    • Unscrew the single screw holding down the clamp that connects the thermal switch (black cylinder) and the white wire to the body of the hot pot.
  11. Kitchen Gourmet WM-6105 Disassembly: étape 11, image 1 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 11, image 2 de 3 Kitchen Gourmet WM-6105 Disassembly: étape 11, image 3 de 3
    • Remove the clamp holding down the thermal switch and white wire.
    • There is thermal grease between the thermal switch and the metal base of the hot pot. Once the bracket comes off, and the switch comes unattached, you may need to reapply it if you plan to reattach the switch.
Giulia Puppin
Membre depuis le 09/13/23
243 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 4
Total : 101
