Introduction
If your kitchen strainer seems to be leaking from the bottom, what you need is a replacement of the kitchen basket strainer assembly.
Cracks, old washers, and parts can wear over time. If not dealt with, the leaks under your sink will become worse. The quicker you use this guide, the better.
Inspect your current plumbing under the sink to determine how much space you have to work with. Whether or not you will need a wrench to loosen some of the parts. Draw a diagram if needed. You will also have to purchase a new kitchen strainer assembly that has similar dimensions to your current strainer.
Technically, this entire guide does not require a wrench. But if the lock nuts are too tight to loosen, then a wrench is not just recommended - but required. Please do not hurt yourself or break anything by using too much force. Make it easy on yourself.
Before you use this guide, make sure you clear all materials under the sink and place a safeguard (cloth, towel) to make sure the water does not damage your sink cabinet.
Ce dont vous avez besoin
Inspect the strainer under the sink and inspect the basket over the sink. Take out the basket from the top.
By the end of this guide, you should now know the ins and outs of the kitchen strainer and how to replace it.
