Aller au contenu principal
Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly
Ce dont vous avez besoin
  1. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly, Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 1, image 1 de 2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly, Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 1, image 2 de 2
    • At the bottom of the kettle pot, remove two 10 mm screws with a Phillips #2 screwdriver.
  2. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 2, image 1 de 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 2, image 2 de 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 2, image 3 de 3
    • Open the lid of the kettle
    • Remove two 12 mm screws at the top of the handle with a Phillips #2 screwdriver.
  3. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 3, image 1 de 2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 3, image 2 de 2
    • The exterior of the plastic handle and lid can now be removed from the kettle to expose the electric components.
    • The plastic cover may need a little wiggling to pop off.
  4. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 4, image 1 de 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 4, image 2 de 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 4, image 3 de 3
    • Turn the kettle over to the back of the handle.
    • Remove three 10 mm screws connecting the switch circuit to the heating element with a Phillips #2 screwdriver.
    • The heating element should disconnect, allowing you to remove it.
  5. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 5, image 1 de 2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 5, image 2 de 2
    • The pronged power element, removed in Step 4, will have a dry-heating safety feature on the opposite side.
    • This switch turns off the kettle once steam is detected, indicating the water is boiling.
    • This is the boil dry protection switch.
  6. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 6, image 1 de 2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 6, image 2 de 2
    • The inner heating element can now be removed after the completion of Step 4.
  7. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 7, image 1 de 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 7, image 2 de 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: étape 7, image 3 de 3
    • Looking at the bottom of the base, remove two 12 mm screws from the base with a Triangle #2 screwdriver.
    • You are now able to take the black plastic cover off and remove the cord.
Pièces jointes
Amanda Yan
Membre depuis le 09/14/22
195 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 39
Total : 826
