Aller au contenu principal
KitchenAid KHM512ER Beater Rings Replacement
Ce dont vous avez besoin
  1. KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: étape 1, image 1 de 2 KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: étape 1, image 2 de 2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Beater Rings Replacement: étape 2, image 1 de 2 KitchenAid KHM512ER Beater Rings Replacement: étape 2, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
  3. KitchenAid KHM512ER Beater Rings Replacement: étape 3, image 1 de 2 KitchenAid KHM512ER Beater Rings Replacement: étape 3, image 2 de 2
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
  4. KitchenAid KHM512ER Beater Rings Replacement: étape 4, image 1 de 2 KitchenAid KHM512ER Beater Rings Replacement: étape 4, image 2 de 2
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  5. KitchenAid KHM512ER Beater Rings Replacement: étape 5, image 1 de 2 KitchenAid KHM512ER Beater Rings Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Lie the motor down flat on a table.
    • Using a pair of tweezers, remove the ring from the plastic knob.
4 autres ont terminé cette réparation.
Brad Daniels
Membre depuis le 02/10/16
621 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 2-3, Sullivan Spring 2016 Membre de l'équipe USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 membres
4 tutoriels rédigés
3 commentaires
Anyone know of a site that sells replacement beater gears?
joescherzo - Réponse
Nice set by step process but where does one get the rings?
M Stevens - Réponse
try Sears parts.com
Yvette Tower - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 47
Total : 6,737
