Aller au contenu principal
KitchenAid KSB5CR Ribbon Cable Replacement
Ce dont vous avez besoin
  1. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: étape 1, image 1 de 3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: étape 1, image 2 de 3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: étape 1, image 3 de 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 2: étape 2, image 1 de 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: étape 3, image 1 de 2 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: étape 3, image 2 de 2
    • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
  4. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Ribbon Cable: étape 4, image 1 de 1
    • Remove the ribbon cable from the chassis by lifting it up.
    • Remove the other end of the ribbon cable from the circuit board by lifting it up.
Cameron Geehr
Membre depuis le 09/28/14
745 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 12-5, Forte Fall 2014 Membre de l'équipe Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 492
