Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Kobo Clara BW (N365) Back Cover Replacement
Ce dont vous avez besoin
    1. Kobo Clara BW (N365) Back Cover Replacement, Before you begin: étape 1, image 1 de 3 Kobo Clara BW (N365) Back Cover Replacement, Before you begin: étape 1, image 2 de 3 Kobo Clara BW (N365) Back Cover Replacement, Before you begin: étape 1, image 3 de 3
      • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
      • Optionally, to drain the battery faster, navigate to MoreSettingsEnergy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
      • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
      • Unplug all cables and fully shut down your eReader.
      • Your screen should be black and say Powered off.
      Demander à FixBot
      Ajouter un commentaire
    1. Kobo Clara BW (N365) Back Cover Replacement, Insert an opening pick: étape 2, image 1 de 2 Kobo Clara BW (N365) Back Cover Replacement, Insert an opening pick: étape 2, image 2 de 2
      • Lay your eReader down so the back cover is facing up.
      • Insert the flat edge of an opening pick between the frame and the bottom left corner of the back cover.
      • Push the pick downwards at a slight angle until it slides under the back cover.
      Demander à FixBot
    2. Kobo Clara BW (N365) Back Cover Replacement, Release the bottom clips: étape 3, image 1 de 3 Kobo Clara BW (N365) Back Cover Replacement, Release the bottom clips: étape 3, image 2 de 3 Kobo Clara BW (N365) Back Cover Replacement, Release the bottom clips: étape 3, image 3 de 3
      • Slide the pick toward the bottom right corner to release the clips along the bottom edge.
      Demander à FixBot
    3. Kobo Clara BW (N365) Back Cover Replacement: étape 4, image 1 de 2 Kobo Clara BW (N365) Back Cover Replacement: étape 4, image 2 de 2
      • Remove the pick and reinsert it under the bottom left corner.
      • Angle the pick flat under the back cover and rotate it around the bottom left corner to release its clips.
      • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
      Demander à FixBot
    4. Kobo Clara BW (N365) Back Cover Replacement, Release the left clips: étape 5, image 1 de 3 Kobo Clara BW (N365) Back Cover Replacement, Release the left clips: étape 5, image 2 de 3 Kobo Clara BW (N365) Back Cover Replacement, Release the left clips: étape 5, image 3 de 3
      • Slide the pick toward the top left corner to release the clips along the left edge.
      Demander à FixBot
    5. Kobo Clara BW (N365) Back Cover Replacement, Remove the back cover: étape 6, image 1 de 3 Kobo Clara BW (N365) Back Cover Replacement, Remove the back cover: étape 6, image 2 de 3 Kobo Clara BW (N365) Back Cover Replacement, Remove the back cover: étape 6, image 3 de 3
      • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
      • Grip the left edge of the back cover and lift it away from the eReader to release the remaining clips.
      • Remove the back cover.
      • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
      Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
247 410 Réputation
1 203 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
76 843 tutoriels rédigés
2 commentaires de tutoriel
une fois ouverte comment aller plus loin pour réparer une liseuse KOBO aura H20 dont un vendeur FNac assure que c'est irréparable (difficile à ouvrir et trop fragile ) ?
latour - Réponse Partager
mise en place du compte
merci de répondre
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 24
30 derniers jours : 194
Total : 4,662
