Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Kobo Libra Colour (N428B) Battery Replacement
Ce dont vous avez besoin
    1. Kobo Libra Colour (N428B) Battery Replacement, Before you begin: étape 1, image 1 de 3 Kobo Libra Colour (N428B) Battery Replacement, Before you begin: étape 1, image 2 de 3 Kobo Libra Colour (N428B) Battery Replacement, Before you begin: étape 1, image 3 de 3
      • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
      • Optionally, to drain the battery faster, navigate to MoreSettingsEnergy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
      • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
      • Unplug all cables and fully shut down your eReader.
      • Your screen should be black and say Powered off.
      Demander à FixBot
      Ajouter un commentaire
    1. Kobo Libra Colour (N428B) Battery Replacement, Insert an opening pick: étape 2, image 1 de 3 Kobo Libra Colour (N428B) Battery Replacement, Insert an opening pick: étape 2, image 2 de 3 Kobo Libra Colour (N428B) Battery Replacement, Insert an opening pick: étape 2, image 3 de 3
      • Flip your eReader over so the screen is facing down.
      • Angle an opening pick straight down, and insert its tip under the top right corner of the back cover, near the power button.
      • Push downward and pry up with the pick until you feel it slide between one of the clips and the frame.
      • You may have to test a few spots along the corner until the pick slides between one of the clips.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Battery Replacement, Release the right clips: étape 3, image 1 de 3 Kobo Libra Colour (N428B) Battery Replacement, Release the right clips: étape 3, image 2 de 3 Kobo Libra Colour (N428B) Battery Replacement, Release the right clips: étape 3, image 3 de 3
      • Slide the pick toward the bottom right corner to release the clips along the right edge.
      Demander à FixBot
    3. Kobo Libra Colour (N428B) Battery Replacement: étape 4, image 1 de 2 Kobo Libra Colour (N428B) Battery Replacement: étape 4, image 2 de 2
      • Angle the pick flat under the back cover and rotate it around the bottom right corner to release its clips.
      • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
      Demander à FixBot
    4. Kobo Libra Colour (N428B) Battery Replacement, Release the bottom clips: étape 5, image 1 de 3 Kobo Libra Colour (N428B) Battery Replacement, Release the bottom clips: étape 5, image 2 de 3 Kobo Libra Colour (N428B) Battery Replacement, Release the bottom clips: étape 5, image 3 de 3
      • Slide the pick toward the bottom left corner to release the clips along the bottom edge.
      Demander à FixBot
    5. Kobo Libra Colour (N428B) Battery Replacement, Remove the back cover: étape 6, image 1 de 3 Kobo Libra Colour (N428B) Battery Replacement, Remove the back cover: étape 6, image 2 de 3 Kobo Libra Colour (N428B) Battery Replacement, Remove the back cover: étape 6, image 3 de 3
      • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
      • Grip the right edge of the back cover and lift it away from the eReader to release the remaining clips.
      • Remove the back cover.
      • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
      Demander à FixBot
    1. Kobo Libra Colour (N428B) Battery Replacement, Coating information: étape 7, image 1 de 3 Kobo Libra Colour (N428B) Battery Replacement, Coating information: étape 7, image 2 de 3 Kobo Libra Colour (N428B) Battery Replacement, Coating information: étape 7, image 3 de 3
      • The entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
      • While this won't hurt your device, removing the coating compromises the device to potential water damage.
      • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
      • Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Battery Replacement, Disconnect the battery: étape 8, image 1 de 2 Kobo Libra Colour (N428B) Battery Replacement, Disconnect the battery: étape 8, image 2 de 2
      • Use a spudger to pry up and disconnect the battery press connector.
      • Don't pry against the motherboard, as you risk breaking small, surface-mounted components.
      • Your E-ink screen will continue to say Powered off even after disconnection—this is normal!
      Demander à FixBot
    1. Kobo Libra Colour (N428B) Battery Replacement, Remove the battery screws: étape 9, image 1 de 2 Kobo Libra Colour (N428B) Battery Replacement, Remove the battery screws: étape 9, image 2 de 2
      • Be careful not to poke the battery with your screwdriver.
      • Use a Phillips screwdriver to remove the four 2.1 mm‑long screws securing the battery.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Battery Replacement, Remove the battery: étape 10, image 1 de 3 Kobo Libra Colour (N428B) Battery Replacement, Remove the battery: étape 10, image 2 de 3 Kobo Libra Colour (N428B) Battery Replacement, Remove the battery: étape 10, image 3 de 3
      • Use your fingers to lift and remove the battery.
      • If you're transferring the battery to a new screen, inspect the battery for any dents or deformations.
      • Never reuse a damaged battery! If your battery shows any signs of damage, replace it with a new one.
      Demander à FixBot
Remember: after repairs, your eReader is no longer IPX8 waterproof.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Make sure each of your device's main functions still work, e.g., LED backlight, touch, Wi-Fi, etc.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Spencer Day
Membre depuis le 09/14/22
202 331 Réputation
1 244 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 22
30 derniers jours : 111
Total : 871
