Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Kobo Libra Colour (N428B) Motherboard Replacement
Ce dont vous avez besoin
    1. Kobo Libra Colour (N428B) Motherboard Replacement, Before you begin: étape 1, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Before you begin: étape 1, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Before you begin: étape 1, image 3 de 3
      • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
      • Optionally, to drain the battery faster, navigate to MoreSettingsEnergy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
      • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
      • Unplug all cables and fully shut down your eReader.
      • Your screen should be black and say Powered off.
      Demander à FixBot
      Ajouter un commentaire
    1. Kobo Libra Colour (N428B) Motherboard Replacement, Insert an opening pick: étape 2, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Insert an opening pick: étape 2, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Insert an opening pick: étape 2, image 3 de 3
      • Flip your eReader over so the screen is facing down.
      • Angle an opening pick straight down, and insert its tip under the top right corner of the back cover, near the power button.
      • Push downward and pry up with the pick until you feel it slide between one of the clips and the frame.
      • You may have to test a few spots along the corner until the pick slides between one of the clips.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Motherboard Replacement, Release the right clips: étape 3, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Release the right clips: étape 3, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Release the right clips: étape 3, image 3 de 3
      • Slide the pick toward the bottom right corner to release the clips along the right edge.
      Demander à FixBot
    3. Kobo Libra Colour (N428B) Motherboard Replacement: étape 4, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement: étape 4, image 2 de 2
      • Angle the pick flat under the back cover and rotate it around the bottom right corner to release its clips.
      • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
      Demander à FixBot
    4. Kobo Libra Colour (N428B) Motherboard Replacement, Release the bottom clips: étape 5, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Release the bottom clips: étape 5, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Release the bottom clips: étape 5, image 3 de 3
      • Slide the pick toward the bottom left corner to release the clips along the bottom edge.
      Demander à FixBot
    5. Kobo Libra Colour (N428B) Motherboard Replacement, Remove the back cover: étape 6, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the back cover: étape 6, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the back cover: étape 6, image 3 de 3
      • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
      • Grip the right edge of the back cover and lift it away from the eReader to release the remaining clips.
      • Remove the back cover.
      • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
      Demander à FixBot
    1. Kobo Libra Colour (N428B) Motherboard Replacement, Coating information: étape 7, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Coating information: étape 7, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Coating information: étape 7, image 3 de 3
      • The entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
      • While this won't hurt your device, removing the coating compromises the device to potential water damage.
      • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
      • Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the battery: étape 8, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the battery: étape 8, image 2 de 2
      • Use a spudger to pry up and disconnect the battery press connector.
      • Don't pry against the motherboard, as you risk breaking small, surface-mounted components.
      • Your E-ink screen will continue to say Powered off even after disconnection—this is normal!
      Demander à FixBot
    1. Kobo Libra Colour (N428B) Motherboard Replacement, Soften the digitizer cables coating: étape 9, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement, Soften the digitizer cables coating: étape 9, image 2 de 2
      • Heat an iOpener and lay it on the digitizer cable ZIF connectors for 90 seconds to soften the coating.
      • Alternatively, you can use a hair dryer or a heat gun for 30 seconds.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Motherboard Replacement, Remove the coating: étape 10, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the coating: étape 10, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the coating: étape 10, image 3 de 3
      Outil utilisé dans cette étape :
      • Use the tip of a spudger to scrape the coating along the ZIF connectors' black locking tabs—enough so you can grab clumps of it with pointed tweezers.
      • Use pointed tweezers to peel off the coating around the black locking tabs and their hinges on the ZIF connector.
      • If the coating becomes too brittle and hard to peel off, reheat the connectors and try again.
      • This is a meticulous process! Failure to remove enough of the coating could damage the locking tab during disconnection, so take your time!
      Demander à FixBot
    3. Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the digitizer cables: étape 11, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the digitizer cables: étape 11, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the digitizer cables: étape 11, image 3 de 3
      • Use the point of a spudger to lift up the locking tabs on the ZIF connectors.
      • The locking tabs should be nearly vertical when unlocked. If not, remove more coating until the tabs can move freely.
      Demander à FixBot
    4. Kobo Libra Colour (N428B) Motherboard Replacement, Reheat the digitizer cables: étape 12, image 1 de 1
      • Apply a heated iOpener to the digitizer cable ZIF connectors for 90 seconds to soften the coating.
      Demander à FixBot
    5. Kobo Libra Colour (N428B) Motherboard Replacement: étape 13, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement: étape 13, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement: étape 13, image 3 de 3
      • Slide one arm of a pair of pointed tweezers underneath the cables to separate the coating securing them to the motherboard.
      • You only need to separate enough coating so you can grip the cables with blunt nose tweezers.
      Demander à FixBot
    6. Kobo Libra Colour (N428B) Motherboard Replacement: étape 14, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement: étape 14, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement: étape 14, image 3 de 3
      • Because of the awkward angle, this step requires some patience to avoid tearing the cables. Work slowly and apply heat regularly.
      • Use blunt nose tweezers to pull the cables away from their ZIF connectors slowly and steadily at a level angle to separate the coating.
      • Gripping the tweezers closer to the tip can help get a tighter hold on the cables.
      • Keep pulling on the cables until they're completely disconnected.
      • During reassembly:
      • Inspect the ends of the cables and the ZIF connectors for any remaining coating that could prevent a good connection.
      • Peel off the coating, heating the cable and the ZIF connectors when the coating becomes too brittle.
      • It doesn't have to look pretty! You just need to remove enough coating to have the cables sit properly in their connectors.
      Demander à FixBot
    7. Kobo Libra Colour (N428B) Motherboard Replacement, Soften the display cable coating: étape 15, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement, Soften the display cable coating: étape 15, image 2 de 2
      • Apply a heated iOpener to the display cable ZIF connector for 90 seconds to soften the coating.
      Demander à FixBot
    8. Kobo Libra Colour (N428B) Motherboard Replacement, Remove the coating: étape 16, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the coating: étape 16, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the coating: étape 16, image 3 de 3
      • The display cable ZIF connector is larger and requires a different procedure to disconnect properly.
      • Use the tip of a spudger to scrape the coating along the ZIF connector's black locking tab—enough so you can grab clumps of it with pointed tweezers.
      Demander à FixBot
    9. Kobo Libra Colour (N428B) Motherboard Replacement: étape 17, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement: étape 17, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement: étape 17, image 3 de 3
      • Use pointed tweezers to peel off the coating around the locking tab and its hinge on the ZIF connector.
      • If the coating becomes too brittle and hard to peel off, reheat the connector and try again.
      Demander à FixBot
    10. Kobo Libra Colour (N428B) Motherboard Replacement: étape 18, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement: étape 18, image 2 de 2
      • Use the flat end of a spudger to gently pry along the length of the locking tab to separate any remaining coating.
      • Don't pry hard at the corners of the locking tab to avoid snapping it.
      Demander à FixBot
    11. Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the display cable: étape 19, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the display cable: étape 19, image 2 de 2
      • Insert the flat end of a spudger under the middle of the locking tab and lift to unlock it.
      • The locking tab should be nearly vertical when unlocked. If not, remove more coating until the tab can move freely.
      Demander à FixBot
    12. Kobo Libra Colour (N428B) Motherboard Replacement: étape 20, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement: étape 20, image 2 de 2
      • Use blunt nose tweezers to grip the corner of the display cable closest to the charging port.
      • Pull the cable away from the ZIF connector slowly and steadily at a level angle to separate the coating at the corner.
      • If you're having trouble, try rocking the cable side-to-side while pulling.
      • Gripping the tweezers closer to the tip can help with getting a tighter hold on the cable.
      Demander à FixBot
    13. Kobo Libra Colour (N428B) Motherboard Replacement: étape 21, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement: étape 21, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement: étape 21, image 3 de 3
      • Repeat the previous step for the other corner until the entire cable is disconnected.
      • Lift up the cable and peel off any remaining coating holding it to the motherboard.
      • Inspect the ends of the cable and the ZIF connectors for any remaining coating that could prevent a good connection.
      • Peel off the coating, heating the cable and the ZIF connector when the coating becomes too brittle.
      • It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in the connector.
      Demander à FixBot
    1. Kobo Libra Colour (N428B) Motherboard Replacement, Soften the ZIF connector coating: étape 22, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement, Soften the ZIF connector coating: étape 22, image 2 de 2
      • Heat an iOpener and lay it on the power button ZIF connector (near the top right corner of the motherboard) for 90 seconds to soften the coating.
      • Alternatively, you can use a hair dryer or heat gun for 30 seconds to soften the coating.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Motherboard Replacement, Remove the coating: étape 23, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the coating: étape 23, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the coating: étape 23, image 3 de 3
      • Use the tip of a spudger and pointed tweezers to scrape and remove the coating from the ZIF connector's locking tab and cable.
      • If the coating becomes too brittle and hard to peel off, reheat the power button board and try again.
      Demander à FixBot
    3. Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the power button cable: étape 24, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the power button cable: étape 24, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Disconnect the power button cable: étape 24, image 3 de 3
      • Use the tip of a spudger to lift up the locking tab on the power button ZIF connector.
      • Use angled tweezers to push the cable fully out of its socket, pushing on the small "arms" near the head of the cable.
      • If you're having trouble, you can use your fingers to gently pull on the cable—don't grip the cable with tweezers or you may damage it.
      Demander à FixBot
    1. Kobo Libra Colour (N428B) Motherboard Replacement, Remove the motherboard screws: étape 25, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the motherboard screws: étape 25, image 2 de 2
      • Use a Phillips screwdriver to remove the seven screws securing the motherboard:
      • Four 2.4 mm‑long screws
      • Three 3.9 mm‑long screws
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Motherboard Replacement, Unclip the motherboard: étape 26, image 1 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Unclip the motherboard: étape 26, image 2 de 3 Kobo Libra Colour (N428B) Motherboard Replacement, Unclip the motherboard: étape 26, image 3 de 3
      • Four tabs secure the motherboard in place—two plastic ones on the outer edge, and two metal ones near the battery.
      • Be very careful not to damage any of the small, surface‑mounted components on the motherboard during this step.
      • Insert the tip of an opening pick betwen the motherboard and the plastic buffer beneath it, near one of the plastic clips on the outer edge.
      • Gently twist the pick to release the clip.
      • Repeat the process to release the other plastic clip.
      • During reassembly, gently press down near the center of the board's outer edge to engage the two plastic clips.
      Demander à FixBot
    3. Kobo Libra Colour (N428B) Motherboard Replacement, Remove the motherboard: étape 27, image 1 de 2 Kobo Libra Colour (N428B) Motherboard Replacement, Remove the motherboard: étape 27, image 2 de 2
      • Grip the outer corners of the motherboard with your fingers and slide the board over the left edge to remove it.
      • Don't lift the board, or the tabs near the battery may damage it.
      • Slide the board into place so the inner edge (opposite the USB‑C port) goes under the two metal tabs.
      • Lower the board into its recess, making sure no cables get stuck under the board. Ensure the corner screw holes go over their alignment posts.
      • If a cable gets stuck, use a spudger to gently pull it out. If you're having trouble, remove the board and try again.
      Demander à FixBot
Remember: after repairs, your eReader is no longer IPX8 waterproof.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Make sure each of your device's main functions still work, e.g., LED backlight, touch, page-turn buttons, Wi-Fi, etc.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Spencer Day
Membre depuis le 09/14/22
202 301 Réputation
1 244 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 52
Total : 409
