Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Kobo Libra Colour (N428B) Power Button Replacement
Ce dont vous avez besoin
    1. Kobo Libra Colour (N428B) Power Button Replacement, Before you begin: étape 1, image 1 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Before you begin: étape 1, image 2 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Before you begin: étape 1, image 3 de 3
      • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
      • Optionally, to drain the battery faster, navigate to MoreSettingsEnergy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
      • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
      • Unplug all cables and fully shut down your eReader.
      • Your screen should be black and say Powered off.
      Demander à FixBot
      Ajouter un commentaire
    1. Kobo Libra Colour (N428B) Power Button Replacement, Insert an opening pick: étape 2, image 1 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Insert an opening pick: étape 2, image 2 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Insert an opening pick: étape 2, image 3 de 3
      • Flip your eReader over so the screen is facing down.
      • Angle an opening pick straight down, and insert its tip under the top right corner of the back cover, near the power button.
      • Push downward and pry up with the pick until you feel it slide between one of the clips and the frame.
      • You may have to test a few spots along the corner until the pick slides between one of the clips.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Power Button Replacement, Release the right clips: étape 3, image 1 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Release the right clips: étape 3, image 2 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Release the right clips: étape 3, image 3 de 3
      • Slide the pick toward the bottom right corner to release the clips along the right edge.
      Demander à FixBot
    3. Kobo Libra Colour (N428B) Power Button Replacement: étape 4, image 1 de 2 Kobo Libra Colour (N428B) Power Button Replacement: étape 4, image 2 de 2
      • Angle the pick flat under the back cover and rotate it around the bottom right corner to release its clips.
      • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
      Demander à FixBot
    4. Kobo Libra Colour (N428B) Power Button Replacement, Release the bottom clips: étape 5, image 1 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Release the bottom clips: étape 5, image 2 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Release the bottom clips: étape 5, image 3 de 3
      • Slide the pick toward the bottom left corner to release the clips along the bottom edge.
      Demander à FixBot
    5. Kobo Libra Colour (N428B) Power Button Replacement, Remove the back cover: étape 6, image 1 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Remove the back cover: étape 6, image 2 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Remove the back cover: étape 6, image 3 de 3
      • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
      • Grip the right edge of the back cover and lift it away from the eReader to release the remaining clips.
      • Remove the back cover.
      • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
      Demander à FixBot
    1. Kobo Libra Colour (N428B) Power Button Replacement, Coating information: étape 7, image 1 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Coating information: étape 7, image 2 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Coating information: étape 7, image 3 de 3
      • The entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
      • While this won't hurt your device, removing the coating compromises the device to potential water damage.
      • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
      • Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Power Button Replacement, Disconnect the battery: étape 8, image 1 de 2 Kobo Libra Colour (N428B) Power Button Replacement, Disconnect the battery: étape 8, image 2 de 2
      • Use a spudger to pry up and disconnect the battery press connector.
      • Don't pry against the motherboard, as you risk breaking small, surface-mounted components.
      • Your E-ink screen will continue to say Powered off even after disconnection—this is normal!
      Demander à FixBot
    1. Kobo Libra Colour (N428B) Power Button Replacement, Soften the ZIF connector coating: étape 9, image 1 de 2 Kobo Libra Colour (N428B) Power Button Replacement, Soften the ZIF connector coating: étape 9, image 2 de 2
      • Heat an iOpener and lay it on the power button ZIF connector (near the top right corner of the motherboard) for 90 seconds to soften the coating.
      • Alternatively, you can use a hair dryer or heat gun for 30 seconds to soften the coating.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Power Button Replacement, Remove the coating: étape 10, image 1 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Remove the coating: étape 10, image 2 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Remove the coating: étape 10, image 3 de 3
      • Use the tip of a spudger and pointed tweezers to scrape and remove the coating from the ZIF connector's locking tab and cable.
      • If the coating becomes too brittle and hard to peel off, reheat the power button board and try again.
      • This is a meticulous process! Failure to remove enough of the coating could damage the locking tab during disconnection, so take your time!
      Demander à FixBot
    3. Kobo Libra Colour (N428B) Power Button Replacement, Disconnect the power button cable: étape 11, image 1 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Disconnect the power button cable: étape 11, image 2 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Disconnect the power button cable: étape 11, image 3 de 3
      • Use the tip of a spudger to lift up the locking tab on the power button ZIF connector.
      • The locking tab should be nearly vertical when unlocked. If not, remove more coating until the tab can move freely.
      • Use angled tweezers to push the cable fully out of its socket, pushing on the small "arms" near the head of the cable.
      • If you're having trouble, you can use your fingers to gently pull on the cable—don't grip the cable with tweezers or you may damage it.
      Demander à FixBot
    1. Kobo Libra Colour (N428B) Power Button Replacement, Heat the power button and its cable: étape 12, image 1 de 2 Kobo Libra Colour (N428B) Power Button Replacement, Heat the power button and its cable: étape 12, image 2 de 2
      • The power button and its cable are adhered to the frame.
      • Lay a heated iOpener on the power button and its cable for 90 seconds to soften the adhesive.
      • Alternatively, you can use a hair dryer or heat gun for 30 seconds to heat the power button and its cable.
      Demander à FixBot
    2. Kobo Libra Colour (N428B) Power Button Replacement, Separate the cable and button adhesive: étape 13, image 1 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Separate the cable and button adhesive: étape 13, image 2 de 3 Kobo Libra Colour (N428B) Power Button Replacement, Separate the cable and button adhesive: étape 13, image 3 de 3
      • Carefully slide an opening pick under the cable and power button to separate the adhesive.
      • Work slowly to avoid creasing or folding the cable, and apply more heat if the cable or button feel stuck.
      Demander à FixBot
    3. Kobo Libra Colour (N428B) Power Button Replacement, Remove the power button: étape 14, image 1 de 1
      • Remove the power button.
      • During reassembly:
      • Use a spudger to remove any remnants of the power button adhesive from the frame.
      • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filters) to clean up any adhesive residue.
      • If your power button comes with adhesive pre‑installed, remove the liners. If it doesn't, apply thin, double‑sided tape to the frame where the old adhesive was.
      • Align the power button's cutouts with their pegs on the frame and push the button into place to secure it.
      • Don't secure the cable with adhesive just yet. Wait until after you've reconnected the cable to ensure it will reach the socket.
      Demander à FixBot
Remember: after repairs, your eReader is no longer IPX8 waterproof.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Make sure each of your device's main functions still work, e.g., LED backlight, touch, page-turn buttons, Wi-Fi, etc.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Spencer Day
Membre depuis le 09/14/22
201 670 Réputation
1 244 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 25
30 derniers jours : 95
Total : 412
