Aller au contenu principal
Introduction
The guide will show you how to remove and replace the batteries in your camera.
Outils
Aucun outil spécifié.
Pièces
  1. First, open the cover to the batteries.  This is located on the bottom left of the camera. Push the door down and to the left to open.   This opens into the batteries and the memory card. Push the door down and to the left to open.   This opens into the batteries and the memory card.
    • First, open the cover to the batteries. This is located on the bottom left of the camera.
    • Push the door down and to the left to open. This opens into the batteries and the memory card.
  2. To insert the batteries, place them in the slots provided. Make sure the positive and negative signs match with the positive and negative sides of the batteries. Make sure the positive and negative signs match with the positive and negative sides of the batteries.
    • To insert the batteries, place them in the slots provided.
    • Make sure the positive and negative signs match with the positive and negative sides of the batteries.
  3. When finished, you should have one battery positive side up and the other one negative side up. When finished, you should have one battery positive side up and the other one negative side up. When finished, you should have one battery positive side up and the other one negative side up.
    • When finished, you should have one battery positive side up and the other one negative side up.
To close the door, push the door down and slide to the right
Alyssa
Membre depuis le 12/04/2012
69 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-22, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 6-22, Amido Spring 2012
CPSU-AMIDO-S12S6G22
4 membres
4 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 1,511
