Introduction
Use this guide to remove and replace the battery door.
Pièces
Aucune pièce nécessaire.
  1. Use your finger tip to slide battery cover door away from the center of the camera.
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Remove the old batteries.
    • Remove the old batteries.
  3. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Remove 7 screws from the outer case with a Phillips #00. All screws are 4.45mm. There are 2 screws on the port side.
    • Remove 7 screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  5. Make sure the battery cap is "up". Pull the outer case off with your hands. Pull the outer case off with your hands.
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  6. Make sure the battery door is open. Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
    • Make sure the battery door is open.
    • Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
    • This rod serves as the hinge for the door.
    • Make sure not to lose the battery door spring which may fall when the rod is removed.
Trevor DeVore
Membre depuis le 15/04/2010
17 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 26-19, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 membres
7 tutoriels rédigés
Where do I buy a new battery door. Cheers, Peter
Peter - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 4,563
