Aller au contenu principal
Introduction
How to remove the buttons.
Pièces
Aucune pièce spécifiée.
  1. Position the camera with the bottom facing up. With your finger, slide the battery cover in the direction of open arrow. The battery cover will spring open, so be careful to lift it up gently.
    • Position the camera with the bottom facing up.
    • With your finger, slide the battery cover in the direction of open arrow.
    • The battery cover will spring open, so be careful to lift it up gently.
  2. Use a Phillips #00 screwdriver to remove the seven 4.5mm screws. There are 2 on the left There are 2 on the right
    • Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
    • There are 2 on the left
    • There are 2 on the right
    • There are 3 on the bottom
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off.
    • Firmly grasp and pull back casing off.
  5. Use #00 screwdriver to pry off buttons. Use #00 screwdriver to pry off buttons. Use #00 screwdriver to pry off buttons.
    • Use #00 screwdriver to pry off buttons.
Alan Galarza
Membre depuis le 03/10/2010
69 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-51, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 membres
7 tutoriels rédigés
Thank you this was very helpful!
carolnelson - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,183
