Introduction
Use this guide to remove and install the front case.
Pièces
Aucune pièce nécessaire.
  1. Position the camera with the bottom facing up.
    • Position the camera with the bottom facing up.
    • With your finger, slide the battery cover in the direction of open arrow.
    • The battery cover will spring open, so be careful to lift it up gently.
  2. Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
    • Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
      • There are 2 on the left
      • There are 2 on the right
      • There are 3 on the bottom
    • Firmly grasp and pull back casing off.
    • With battery door open, grasp the front case and remove it from the camera.
Dustin Rodgers
Membre depuis le 05/10/2010
50 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 7-51, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,640
