Aller au contenu principal
Kodak EasyShare LS743 Battery Door Replacement
Ce dont vous avez besoin
  1. Kodak EasyShare LS743 Battery Door Replacement, Battery: étape 1, image 1 de 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Battery Door Replacement: étape 2, image 1 de 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: étape 3, image 1 de 3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: étape 3, image 2 de 3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: étape 3, image 3 de 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Battery Door Replacement: étape 4, image 1 de 3 Kodak EasyShare LS743 Battery Door Replacement: étape 4, image 2 de 3 Kodak EasyShare LS743 Battery Door Replacement: étape 4, image 3 de 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Battery Door Replacement: étape 5, image 1 de 2 Kodak EasyShare LS743 Battery Door Replacement: étape 5, image 2 de 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Battery Door Replacement, Battery Door: étape 6, image 1 de 2 Kodak EasyShare LS743 Battery Door Replacement, Battery Door: étape 6, image 2 de 2
    • Remove loose battery door.
Odessa
Membre depuis le 06/24/10
55 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 2-8, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,698
