Introduction
This will teach you how to remove the capacitor in your Kodak EasyShare LS743.
  1. Open the battery cover.
    • Open the battery cover.
  2. Slide the orange latch sideways to eject the battery.
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery.
    • Remove 7 screws.
      • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
      • 4 (4.45mm) screws on the bottom of the camera.
      • 2 (2.95mm) screws on the left side of the camera.
    • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
    • Remove the rear camera casing.
    • Remove the front casing.
    • The capacitor can store electricity even when the camera is off! Do not touch it until you have safely discharged it.
    • Connect the two capacitor wires briefly with a pair of metal tweezers to discharge it. You may see a small spark.
    • Remove 8 screws.
      • 2 screws in the front (2X 4.31mm).
      • 2 screws on the bottom (2X3.30MM).
      • 4 screws in the back (3x 3.33mm, and 1x 4.34mm).
    • Remove and set aside the tripod mount.
    • Pull the black latch outward slightly to release the flex cable.
    • Carefully disconnect the orange flex cable.
    • Desolder both wires and remove them.
    • Remove the capacitor (attached by adhesive) and desolder.
Elizabeth Loui
Membre depuis le 24/06/2010
76 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 2-8, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,002
