Aller au contenu principal
Kodak EasyShare V570 Case Replacement
Ce dont vous avez besoin
  1. Kodak EasyShare V570 Case Replacement, Case: étape 1, image 1 de 2 Kodak EasyShare V570 Case Replacement, Case: étape 1, image 2 de 2
    • Here is the front, back, and right side of the camera.
  2. Kodak EasyShare V570 Case Replacement: étape 2, image 1 de 3 Kodak EasyShare V570 Case Replacement: étape 2, image 2 de 3 Kodak EasyShare V570 Case Replacement: étape 2, image 3 de 3
    • There are going to be four #000 screws on the left side of the camera.
    • Remove the four corner screws using a Philips #000 Screwdriver.
    • On the right side of the camera, remove the two Phillips #000 screws at the bottom.
    • On the underside of the camera, remove the three Phillips #000 screws.
  3. Kodak EasyShare V570 Case Replacement: étape 3, image 1 de 3 Kodak EasyShare V570 Case Replacement: étape 3, image 2 de 3 Kodak EasyShare V570 Case Replacement: étape 3, image 3 de 3
    • As soon as all the screws from the casing are removed, use the iFixit opening pick to slide around the border.
    • If the cover appears loose, try to take it off (with your fingers) while slightly wiggling it, and it should detach.
  4. Kodak EasyShare V570 Case Replacement: étape 4, image 1 de 2 Kodak EasyShare V570 Case Replacement: étape 4, image 2 de 2
    • Here is what the camera looks like with both of the covers taken off.
    • The T-W button is upside down.
    • To put the top and back camera covers back on, follow the steps but in reverse.
Ligne d'arrivée
Isa Hamilton Cruz
Membre depuis le 09/13/23
475 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 92
