Introduction
This guide demonstrates how to install a memory card.
Outils
Aucun outil requis.
Pièces
  1. In order to remove the SD memory card, you will first need to open up the cover. To open the cover, slide the latch holding the cover in place to the left. Remove your hand from the latch and the cover should pop open. The SD memory card is located near the top above the battery. As shown in the final picture of this step.
    • In order to remove the SD memory card, you will first need to open up the cover. To open the cover, slide the latch holding the cover in place to the left.
    • Remove your hand from the latch and the cover should pop open. The SD memory card is located near the top above the battery. As shown in the final picture of this step.
  2. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  3. After locating the SD card, gently push down on the card and release. This will cause the SD card to pop out of its position in the camera as shown in the second picture of this step. After locating the SD card, gently push down on the card and release. This will cause the SD card to pop out of its position in the camera as shown in the second picture of this step.
    • After locating the SD card, gently push down on the card and release. This will cause the SD card to pop out of its position in the camera as shown in the second picture of this step.
  4. After removing the SD card from its locked position, gently pull the SD card out from the container to successfully remove it from the camera. After removing the SD card from its locked position, gently pull the SD card out from the container to successfully remove it from the camera.
    • After removing the SD card from its locked position, gently pull the SD card out from the container to successfully remove it from the camera.
katie newman
Membre depuis le 28/10/2010
30 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-16, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,407
