Aller au contenu principal
Introduction
This guide demonstrates how to replace the door to the battery compartment.
  1. Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Press thumb firmly on battery door and slide it in the direction of the arrow. Lift thumb allowing the door to swing open. Lift thumb allowing the door to swing open.
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
  4. Turn the camera off by firmly pressing the power button located on top of the camera.
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Locate the 7 screws holding the back cover on. Three screws are located on the bottom of the camera. Two screws are located on the side shown in the photograph.
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Remove all 7 screws: Hold the camera firmly with one hand so that you can still see a screw. Place the Philips 00(Found here)screwdriver into the screw.
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Use plastic opening tools to slightly open the side of the case. Insert a plastic opening tool and apply pressure to the internal three tabs at the top. The first two are near the words "3X Optical Zoom".
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Gently pull apart the back cover from the rest of the camera. Make sure there are no more screws or tabs keeping the cover on. Use the plastic opening tool to separate any sides still closely connected.
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Open the battery door. Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Open the battery door.
  10. Use the plastic opening tool to lift the casing around the shutter button. Gently remove the front cover from the device. Gently remove the front cover from the device.
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Do not touch the terminals shown in the photo.  These link to the capacitor which could shock you if not discharged.
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Open the battery door by pulling in direction of arrow Open the battery door by pulling in direction of arrow
    • Open the battery door by pulling in direction of arrow
  13. Use grey wedge(Found here) to push metal pin Use tweezers(Found here)to pull out metal pin Use tweezers(Found here)to pull out metal pin
  14. The spring is small and easy to lose Carefully remove battery door and spring Carefully remove battery door and spring
    • The spring is small and easy to lose
    • Carefully remove battery door and spring
    • Make spring is in correct orientation when putting back
    • The spring should hook onto a small hole in the door
3 autre(s) ont terminé cette réparation.
Susan Marano
Membre depuis le 15/04/2010
300 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 24-22, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 membres
10 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 10,532
