Aller au contenu principal
Introduction
This guide demonstrates how to install a LCD.
  1. Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Press thumb firmly on battery door and slide it in the direction of the arrow. Lift thumb allowing the door to swing open. Lift thumb allowing the door to swing open.
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
  4. Turn the camera off by firmly pressing the power button located on top of the camera.
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Locate the 7 screws holding the back cover on. Three screws are located on the bottom of the camera. Two screws are located on the side shown in the photograph.
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Remove all 7 screws: Hold the camera firmly with one hand so that you can still see a screw. Place the Philips 00(Found here)screwdriver into the screw.
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Kits pour Apple Watch
    Screen and battery repairs just got easier.
    Acheter maintenant
    Acheter maintenant
  8. Use plastic opening tools to slightly open the side of the case. Insert a plastic opening tool and apply pressure to the internal three tabs at the top. The first two are near the words "3X Optical Zoom".
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  9. Gently pull apart the back cover from the rest of the camera. Make sure there are no more screws or tabs keeping the cover on. Use the plastic opening tool to separate any sides still closely connected.
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  10. Open the battery door. Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Open the battery door.
  11. Use the plastic opening tool to lift the casing around the shutter button. Gently remove the front cover from the device. Gently remove the front cover from the device.
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  12. Do not touch the terminals shown in the photo.  These link to the capacitor which could shock you if not discharged.
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  13. Once the front cover is removed, the battery door maybe closed for convenience. Locate the exposed portion of the LCD screen. Use a wedge to free the LCD screen from the medal housing.
    • Once the front cover is removed, the battery door maybe closed for convenience.
    • Locate the exposed portion of the LCD screen.
    • Use a wedge to free the LCD screen from the medal housing.
    • Do not pull the screen away completely, it is still attached to the logic board via the yellow cable.
  14. Remove the screw at the upper right corner of the metal housing.
    • Remove the screw at the upper right corner of the metal housing.
  15. Locate the 2 solder joints holding down the medal housing. Remove the solder. Place wick on solder.
    • Locate the 2 solder joints holding down the medal housing.
    • Remove the solder.
    • Place wick on solder.
    • Place solder iron on wick
    • The wick should be sandwiched between the iron and the solder.
  16. Peel back the black tape from the metal housing. Lift the metal housing from the left so that it hinges on its right side. The metal housing is still loosely attached on its right side.
    • Peel back the black tape from the metal housing.
    • Lift the metal housing from the left so that it hinges on its right side.
    • The metal housing is still loosely attached on its right side.
  17. Locate black tab holding the LCD screen connector in the port. Use wedge or fingernail to lift the black tab. Pull the the LCD screen connector out of the port.
    • Locate black tab holding the LCD screen connector in the port.
    • Use wedge or fingernail to lift the black tab.
    • Pull the the LCD screen connector out of the port.
2 autre(s) ont terminé cette réparation.
Samantha Murray
Membre depuis le 15/04/2010
224 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-22, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 membres
10 tutoriels rédigés
De sluiterknop werkt niet altijd, hoe is dit op te lossen?
Jacobus Rijken - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 12,628
