Aller au contenu principal
Introduction
This guide demonstrates how to install a memory card.
  1. Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
  2. Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow. Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow. Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
    • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
  3. Locate memory card slot and insert memory card by inserting the gold terminals first. Apply pressure into you feel it lock into place.
    • Locate memory card slot and insert memory card by inserting the gold terminals first.
    • Apply pressure into you feel it lock into place.
    • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
  4. Return the battery door to its formerly closed position. Return the battery door to its formerly closed position.
    • Return the battery door to its formerly closed position.
  5. Turn on camera.
Samantha Murray
Membre depuis le 15/04/2010
224 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-22, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 membres
10 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 6,369
