Aller au contenu principal
Kodak S100 EF Flash Capacitor Replacement
Ce dont vous avez besoin
  1. Kodak S100 EF Flash Capacitor Replacement, Back Cover: étape 1, image 1 de 2 Kodak S100 EF Flash Capacitor Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Kodak S100 EF Flash Capacitor Replacement: étape 2, image 1 de 1
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Kodak S100 EF Flash Capacitor Replacement: étape 3, image 1 de 1
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
  4. Kodak S100 EF Flash Capacitor Replacement, Flash Capacitor: étape 4, image 1 de 1
    • The capacitor is located at the bottom center of the camera.
  5. Kodak S100 EF Flash Capacitor Replacement: étape 5, image 1 de 1
Michelle
Membre depuis le 04/04/11
107 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-28, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 5
Total : 2,351
