Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
To start, the Front Cover Teardown guide must be used. Later, soldering guides will be used.
  1. Have the camera facing upwards and the flash closest to you.
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Flip the camera over to the other side-with flash farthest from you.
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  4. Turn the camera so the bottom is facing up with the front-facing away.
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
  5. Once the front cover is off, desolder the connections at both ends of the flash.
Nick
Membre depuis le 26/04/2011
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 25-28, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 15
Total : 1,921
