Aller au contenu principal
Kolcraft Cloud Plus "Free-Stand" Button Replacement
Ce dont vous avez besoin
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: étape 1, image 1 de 2 Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: étape 1, image 2 de 2
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: étape 2, image 1 de 1
    • Remove the back cover of the case by lifting it straight up.
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: étape 3, image 1 de 1
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: étape 4, image 1 de 1
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
Christopher Peterson
Membre depuis le 10/01/15
330 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 11-1, Forte Fall 2015 Membre de l'équipe Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 33
Total : 1,381
