Aller au contenu principal
Introduction
This guide provides instructions on how to replace a broken or cracked LCD screen on your Konica Minolta DiMAGE Z3.
  1. Open the battery chamber door by sliding the door to the side of the camera to release the safety catch. Lift the door up to open.
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Insert the four batteries inside of the battery chamber door.
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
  3. Use a screwdriver to remove the four viewfinder cover screws. Use a screwdriver to remove the four viewfinder cover screws.
    • Use a screwdriver to remove the four viewfinder cover screws.
  4. Remove the 2 small screws under the viewfinder.
    • Remove the 2 small screws under the viewfinder.
  5. Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
  6. Remove 6 screws on the bottom panel.
    • Remove 6 screws on the bottom panel.
  7. Remove 1 screw on the outer side of the battery chamber.
    • Remove 1 screw on the outer side of the battery chamber.
    • This will be under the rubber grip.
  8. Remove 1 screw inside the battery chamber.
    • Remove 1 screw inside the battery chamber.
  9. Pull the wrist strap away from the front of the camera to remove it.
    • Pull the wrist strap away from the front of the camera to remove it.
    • Then carefully pull the back casing apart from the camera.
  10. Remove the 3 screws that attach the LCD screen to the circuit board.
    • Remove the 3 screws that attach the LCD screen to the circuit board.
  11. Gently remove the LCD screen from the circuit board.
    • Gently remove the LCD screen from the circuit board.
    • There will be a ribbon cable and some wires attached to the LCD screen.
  12. Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
Hieu Ngo
Membre depuis le 22/03/2017
431 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S7-G4, Julie Spring 2017 Membre de l'équipe UMass Dartmouth, Team S7-G4, Julie Spring 2017
UMASSD-JULIE-S17S7G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 392
