Aller au contenu principal
Koosh Vortex Tornado Loading Spring Replacement
Ce dont vous avez besoin
  1. Koosh Vortex Tornado Loading Spring Replacement, Barrel Shield Spring: étape 1, image 1 de 1
    • Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
  2. Koosh Vortex Tornado Loading Spring Replacement: étape 2, image 1 de 1
    • Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
  3. Koosh Vortex Tornado Loading Spring Replacement: étape 3, image 1 de 1
    • Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
  4. Koosh Vortex Tornado Loading Spring Replacement, Trigger: étape 4, image 1 de 1
    • Slide the barrel shield and shield slide off of the gun and set aside.
  5. Koosh Vortex Tornado Loading Spring Replacement: étape 5, image 1 de 1
    • Slide the rubber ring off of the barrel and set it aside.
  6. Koosh Vortex Tornado Loading Spring Replacement: étape 6, image 1 de 1
    • Lift the yellow trigger from its pin and set aside.
  7. Koosh Vortex Tornado Loading Spring Replacement, Loading Spring: étape 7, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the two 12 mm long washer head screws from the yellow loading bar lever.
  8. Koosh Vortex Tornado Loading Spring Replacement: étape 8, image 1 de 1
    • Lift the yellow lever bar out of place and set aside.
  9. Koosh Vortex Tornado Loading Spring Replacement: étape 9, image 1 de 1
    • Use a Phillips #1 Screwdriver to unscrew the six 10 mm long screws from the central firing assembly.
    • Use Phillips #1 Screwdriver to unscrew the four 9 mm long screws from the central firing assembly.
  10. Koosh Vortex Tornado Loading Spring Replacement: étape 10, image 1 de 1
    • Pull the shell of the central firing assembly aside off (contains the loading spring).
  11. Koosh Vortex Tornado Loading Spring Replacement: étape 11, image 1 de 2 Koosh Vortex Tornado Loading Spring Replacement: étape 11, image 2 de 2
    • Open the back side of the central firing assembly apart to expose the loading spring. Remove it, and change it with your desired spring.
    • The two sides cannot be fully separated due to a pin holding the yellow collar tightly together.
Lingbin Meng
Membre depuis le 02/16/16
204 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-4, Harley Spring 2016 Membre de l'équipe IUPUI, Team 2-4, Harley Spring 2016
IUPUI-HARLEY-S16S2G4
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 21
Total : 358
