Introduction
If you need to disassemble your Krups CafeExpress FMA110 for repair or spare parts, follow this disassembly guide. Repairs could include a burnt-out heating element, faulty wire connection, ripped tubing, burnt-out thermal fuses, broken temperature switch, etc.
Be sure the device is unplugged before you begin disassembly to avoid burning or electrocuting yourself, which can cause serious injury.
Steps 4 and 6 require pulling silicon tubing off of the device. The tubing can rip easily, so be careful. The opening tools can help with these steps.
Ce dont vous avez besoin
Using the Phillips #1 screwdriver, remove the four 13.8 mm screws on the bottom of the device.
Remove the metal plate.
