Aller au contenu principal
Krups F203 Coffee Grinder Base Plate Replacement
Ce dont vous avez besoin
  1. Krups F203 Coffee Grinder Base Plate Replacement, Base Plate: étape 1, image 1 de 1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Base Plate Replacement: étape 2, image 1 de 3 Krups F203 Coffee Grinder Base Plate Replacement: étape 2, image 2 de 3 Krups F203 Coffee Grinder Base Plate Replacement: étape 2, image 3 de 3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Base Plate Replacement: étape 3, image 1 de 2 Krups F203 Coffee Grinder Base Plate Replacement: étape 3, image 2 de 2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
9 autres ont terminé cette réparation.
Brian Wolfskill
Membre depuis le 10/23/14
420 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team 4-2, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 membres
8 tutoriels rédigés
10 commentaires
Thanks! I was able to repair my broken cord.
wdswaim - Réponse
I'mworking on it as we write .
jerry - Réponse
Does anyone have a video tutorial explaining how the heck one removes the base?? I bought a spudger and it still doesn't help. It is awfully hard to loosen up.. I kept trying and trying but I stopped cause I'm concerned I might break the clips and the outside which the plastic is starting to stretch.. the clips are starting to lose their shape as well and worried I might break the spudger... Thanks
NeonAera - Réponse
I am having the same experience as NeonAera posted. I could clear 2 of the 4 clips, but not the others and getting the same issue of distorting the outside wall of the base , if I continue to try and pry the clips with the spudger. Thanks
Steve Ferrill - Réponse
We had a jammed . I disassembled according to the guide, scraped out the rust I found, lubricated with WD40 and reassembled. Went from not moving to working great. I broke all 4 tabs (guess I lack patience…) but gorilla taped it back together and it's totally solid.
Wade Brainerd - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 9
30 derniers jours : 46
Total : 11,229
